Water Damage Indicator LG Optimus 4x HD
rynmldwny
Hi Just a Very Quick Question , Under the Battery Cover and Next to the Camera Lens there is a White Circle under the Plastic, is that the Water Damage Indicator? I ask as because i dropped my phone it didn't get soaked but it did get wet i put it in rice overnight and it works just fine but from somewhere there is now a spec of dust or something under the glass half way in and level with the volume rocker switch, i've spoken to LG and it's going into there service department so i'm just wondering what there going to say. :confused:
Hi and welcome to Android Forums. There will be a water indicator somewhere. I'm not familiar with your phone so I'm uncertain to it's location. I suspect by now you know the outcome of your question. I hope you return and have good news to report. I hope you enjoy these forums and it's great to have you as member.
