water damaged eris, OS still works!
D
Deleted User
Guest
Hey guys,
So i dropped my HTC eris in the sink the other day. It was submerged for about 5 seconds. The phone then just stopped working and i tried taking out the battery and putting it back in and it wouldn't get passed the screen with the 3 droids on skate boards. I think went ahead and put my phone and battery in rice for a good 18 hours. Tried it again, and now the phone gets passed the 3 droids on skateboards to my lock screen. I receive text messages, the clock works fine and my 3g works fine too. Only problem is my touch screen does not work. I am wondering whta the problem is, and how i can fix it? You think its the digitizer???
Ideally the rice treatment is done before you turn the phone on again after getting it wet. The idea is to remove the moisture before applying electricity and shorting something out. I'd say this is where you use the insurance that you (hopefully) have on the phone. I'd be surprised if it came fully back to life at this point.
