Help waterdamage caused bootlopp (may work)
Hi, i have encountered a problem now after getting waterdamage in my phone, it keeps bootlooping if i just plug in the battery. It doesn't matter if you press any buttons sense it will restart again after a few seconds( so the volume down + startbutton + homebutton commando works, but doesn't keep the phone from continueing to reboot). same as the "loading battery screen" when you plug in the charger.
I'll add that i ordered a new battery sense the old one died instantly. Thought it wouldn't work at all but when i fiddled with if a bit (with the old battery) it briefly came to the "charging battery screen" so i thought buying a new battery was worth a try.
i Would have given up hope but a few days ago it accualy started (dont really know what i did) and i worked for like a minute until it died and started looping again. the phone started once again after that and i heard the "intro sound" once again but then it just starting looping again right after. haven't been able to get anywere sense then and i have opened the whole phone up but don't really know what to do when i finaly in...
the same day as i dropped it in water i had it in the oven on low heat for a while and let it dry as much as possible after.
any suggestions? would be greatly appriciated, sense i have a feeling this all could just be fixed if i just know what to do...
Thanks in advance
Thomas
