Waterproof inside of pack and fix rip at bottom
Rgarner
Android Expert
What would be good for this? Would duct tape work? Thank goodness I at least have some of that, though not a lot, from the dollar store. It's not huge, just about the size a student might take to school, with a main compartment and a smaller one that both zip. By the way, what's good to fix a stubborn zipper? I was told a crayon because of the wax, but it didn't work. Again, though, it's that cheap dollar store kind of crayon.
If it's a good backpack, just with a rip, I'd probably stitch the rip together. Waterproofing is an entirely different thing, though. One can get waterproofing spray at a hardware store.
For stubborn zippers, cleaning the teeth if they are dirty and using something like beeswax might help, but for cheap zippers there really isn't any fixing it.
Cleaning the zipper and applying a light coat of silicone spray might help your zipper. As noted above, if it's a cheap zipper there isn't a lot that can improve it better than it's design. As for water sealing an interior breach I would suggest flex seal tape. It's not a fix all but it does a fair job.
just put a trash bag over the backpack....like this:
:D:D:D:D:D:D
As far as backpacks and other nylon (or whatever) material carrying luggage goes...
unfortunately you are putting a bandaid on a sucking chest wound.
The absoulute best repair?
Probably duct taping the inside (turn the pack inside out first) and the outside and then stiching it around the outside of the repair, and then also crossing through the center a couple/few times.
Then use wax (by rubbing) over the outside.
This is how I fix tents and other such things.
Keep in mind that this repair will be stronger than the original material, so you will experience more problems along side of or near the same areas.
The same repair can be done again, and again.
Eventually, you will have a double duct-taped stiched backpack.
As for the zipper, rub a candle along both sides (in and out) while it is zipped, and then unzip it and do it again along all four sides.
Work it in by zipping and unzipping.
If trouble persists, try using a metal bristle brush along both zipped sides and then wax as above again.
Thanks, I ended up going with the trash bag for now. Aren't you proud of me that I came up with that one on my own? As for a candle, would a votive from the dollar store do?
Yeah, by the time you double side and stitch duct tape over the bag, you will have enough invested in duct tape to have bought another bag, lol.
And you will be carrying around 2 rolls of duct tape everywhere you go.
Surely everyone here only has LV when they travel.
If not, dear God, what kind of people have I been dealing with all this time?
:thinking:
o_O
In all seriousness, I got the paraffin wax, and now what? I have never used this stuff. By the way, is that an actual Chinese HOUSE? I didn't know they had them. I thought it was all apartments. Please forgive my ignorance.
