Hi all,
I bought the Xperia Neo a week ago, and I've been having problems making out going call from it when I'm at home or in a few places around town. It seems that it has full reception and I can get incoming calls and use the internet with 3g - The only problem is with outgoing calls.
I played with the settings and found out that if I put it on GSM only then it works fine, and when I put it in WCDMA only it doesn't work at all in those places.
I replaces the phone to a new one, but the problem remains...
My previous phone was the Xperia x8, and it worked fine on all modes.
Is it a provider problem (T-mobile), a problem with this specific model's antenna? A bug in the software (GB 2.3.3)?
Is there a really big differences between GSM and WCDMA that it's worth getting a different phone over? (Because I really like the Neo)
I'd appreciate a quick replay because I can replace the phone and get another model but I only have a few days to do that...
