Help Weather and Calender Widget not working
luckyluch
Anyone having issues with the weather and calender widgets on their LTEvo? phone is not rooted and when i try to create the widget for either the stock weather app or Calendar pad it goes through the motions of creating it but nothing shows up on screen. :mad: Any advice or suggestions?
I have done that many times and when i go to the screen nothing is there. It sits with the loading circle going around and around and never actually creates the widget... I have sent info to HTC but guess i have to wait to c what happens when they release an update for the phone. Kinda disappointed with the whole thing really. Never preordered a phone with such hype and was so let down with these little issues. (seems to be a lot of little issues with this Evo)
Please hold down your power button for at least 10 seconds - that will force you into a hardware reboot. If you have a bit stuck in memory somehow, that ought to clear it up.
Your data and settings will be safe - this is the equivalent of a battery pull on earlier models.
Are you long-pressing a spot on a homescreen sufficiently large to hold the widget you want, to launch the personalization/widget tool?
I don't hold hope for a software fix to this, I haven't seen this reported elsewhere.
