MonmouthDroid
There are many threads about weatherbug and how it drains battery life on the droid. I have disabled weatherbug's gps, changed the update interval to 4 hours, and taken the widget off my home screen. I still have the status bar notification. I want to be able to run either this or the widget.
Even after all of this weather bug still uses easily 10x more battery during partial wake (according to spare parts) as the next closest app i have, handcent.
Has anyone found a weather app that is reliable and doesn't destroy your battery life like weather bug does. I have been off charger for 7.5 hours and only have 30 percent left with lite to moderate usage (i have 2.0.1, updated this morning). Seeing as i work 8hours, it takes me 30 minutes to get there, and about an hour to get home (traffic), some days it is cutting it pretty close.
