Weather, cost?
Ok thanks, and also can you disable your phone from connecting to the internet by itself, and only connect when you want it to??
You have 2 options: go to settings>accounts and sync and untick the background data and auto-sync boxes or hold down the power button and turn off internet entirely.
Yes.
With option 1, you need to bear in mind that some aps (like mail and the market) have their own autosync options, which will need to be turned off manually.
