The weather animation is an option that comes up when placing the Weather Clock widget on the home screen. If it isn't working currently, just remove the widget and re-add it. It will ask you for a location, I just use current location, then it asks about full screen animation. Check the box and click done. That should do it.
I hope this helps! If not, there are two avenues: You can re-submit your question with additional info the same way you submitted this one, or you can join the forums for a better back and forth exchange of info.
