Help Weather updates on lock screen
D
Deleted User
Guest
I've got the following problem on my lock screen - it seems to be updating my weather from a calendar... which I cannot find to disable.
I've attached a screenshot... has anyone else had the same problem or please know how to fix???
you have a calendar that tells you the sunrise and sunset. try going into your calendar app and selecting "all calendars" to see which calendar it is, then you can take that name and go into personalization settings to remove that calendar from your lock screen notifications
Thank you a thousand times! That worked perfectly.
I would never have thought to go to "Personalization" to set the calendars there.
I've been trying to disable the calendars under the "Calendar" app.
