weatherbug elite
mabergin
Just put weatherbug elite on my phone.I'm new to this so bare with me.Is there a menu on this? How do I save a different location on this.I want to keep my local location at the top but I want to put another location in saved locations.
Do you have your location on the top bar of Elite with a green arrow or a small triangle in the lower right hand corner? Click on it. The popup says- add location. If you have a small icon that looks vaguely like a lightbulb or a hot air balloon, that gives you My Location and your saved locations.
Once you find where to enter the location you want, there is a drop-down menu of all the stations near you. The one in my zip didn't report for a while, so I changed to the airport.
Also the three dots on the top right are a menu. There is a help file that will show you what's where.
