Weatherbug Question...
N9GSU
Hi gang! I did a search of the forums, but didn't find this specific question. I've used WB on my Blackberry for years and loved it. Just upgraded to a 'droid (LG Viper) and the basic app works fine, however...on my home screen, on the BB, WB would show the current temp and conditions. On the droid, it only shows a globe. Is that a difference in the BB version and the droid version, or is there a setting I need to tweak?
Thanks in advance,
Rick
I use the free version of WB and love it. What do you mean that it only shows a globe? I don't see that on mine at all. Maybe uninstall and re-install ?
I've used the WeatherBug Elite (paid version) for a couple of years, and the widget shows the city, current temp, and the next three day forecast. No globe.
My mistake, it's not a globe, it's the "bug". But no info at all unless I open the program itself. Just uninstalled and re downloaded, no change.
I don't think the free version has a widget, only the paid version.
The free version of WB does have a widget. Make sure that you make the widget large enough to show everything. 1 row down and 4 columns across,
