Help Web browser keeps reopening tabs I manually closed
chris90uk
When I open the stock browser after not using it for a while it reloads tabs I closed already. I have found that it is mostly tabs opened by other applications like Flipboard or Rail Planner Live. The tabs I intentionally left open are opened fine.
Is there a way I can stop this as it is really annoying. Thanks!
Yes you can stop very easily by dropping the stock browser and use Dolphin browser instead, I know this is not what you asked but Dolphin Browser is the best browser in Android: Dolphin Browser is
