Web browser with one click access to bookmarks?
Shockwave78
Is there a browser with safari like access to bookmarks? It seems like with the default browser and chrome it takes like 3 or 4 presses to get to your actual bookmarks. With safari on ios, you hit one button and all your bookmarks are there...
Thanks
Thanks
I use Boat, and the bookmarks are accessed via a star in a small task bar at the bottom of the screen.
Dolphin has an option to give access to your bookmarks by a slide to the right, or you can enable a bottom tool bar which has a bookmark link similar to the boat browser.
In the mobile version of Firefox when I hit the search button on my device I reach a page with my most visited sites, my bookmarks & my history...
So it's either 1 click to reach the 'top sites' or 2 clicks to reach the 'bookmarks' here...
With boat, dolphin and opera, the feature you are looking for is called the speed dial. Just enable it and you'll see bookmarks on the homepage.
Sent from my GT-I9003 using Tapatalk 2
Mmmm.... What am I missing?. When I'm browsing with either Dolphin or Opera, speed dial doesn't give me one tap access to bookmarks, unless I open a new tab and although Opera has unlimited bookmarks on speed dial I think Dolphin is limited to ten. With Dolphin if I enable the bottom tool bar I have one tap access or if I enable right slide it gives access to all bookmarks without the need for the bottom tool bar. I prefer the right slide option because it gives full use of the screen.
