the phantom
Hi everyone,
I'm trying to send a call to a web service which takes in two values - one which is a simple integer but the other one is a date value, which is the format of 'dd MMM yyyy'. Apparently the date is fine as a string so I've use the simpledateformat to set it up in the correct fashion.
However when I give the webservice the values it gives me an error message of;
Server was unable to read request. --->There is an error in XML document(1,357). ---> The string '19 Oct 2011' is not a valid ALLXsc value.
The webservice is called by clicking a button. Here is the button code snippet (the rightNow value is a date variable declared earlier that simply gets the current date);
public
void onClick(View arg0) {
SimpleDateFormat dateformatDDMMMYYYY =
new SimpleDateFormat("dd MMM yyyy");
StringBuilder nowddMMMYYYY =
new StringBuilder( dateformatDDMMMYYYY.format( rightNow ) );
TodayDate = nowddMMMYYYY.toString();
getJobs();
The getJobs function code is below (the ResId value is an integer setup earlier);
public
void getJobs() {
SoapObject Request =
new SoapObject(NAMESPACE, METHOD_NAME);
Request.addProperty(
"DateToGet",TodayDate);
"Resource_Id",ResId);
SoapSerializationEnvelope envelope =
new SoapSerializationEnvelope(SoapEnvelope.VER11);
envelope.
dotNet = true;
envelope.setOutputSoapObject(Request);
AndroidHttpTransport aht =
new AndroidHttpTransport(URL);
try
aht.call(
SOAP_ACTION, envelope);
SoapObject response = (SoapObject)envelope.getResponse();
Desc = response.getProperty("Description").toString();
catch(Exception e)
e.printStackTrace();
listJ.setText(e.getMessage());
When it is run it always goes to the catch part and displays the error message in the listJ textbox, all of the webservice details are fine as I called another webservice form the same location before in the app.
Has anyone go any ideas or could try to elaborate on the error message?
Thanks
public
getJobs();
public
void getJobs() {
envelope.
dotNet = true;
try
aht.call(
catch(Exception e)
Thanks
