This is on an Atrix 2 with Lapdock 100 on T-Mobile with ICS and Webtop 3.0. Everything I hook the phone up to the Lapdock, Webtop comes up for a second, then, it goes into Mirror/Mobile View with no way to switch back to Webtop. I've turned the phone off and on again, nothing, then, I pulled the battery, and again, no difference. I did see on a post somewhere that they had issues with the ICS download, and they had to do a factory reset, and all is well. Does anyone thing this might be the solution for this? Thanks!
Jerry
Jerry
