Apps (Webview/HTML) Get Source Code Form an element in a frame
XVirus
JavaScript:
document.getElementById('blockrandom').contentWindow.document.getElementsByTagName('frame')[1]
I use this to access the frame. I want a string with the sourcecode of an element from the frame( after that I will use
Java:
table.setText(Html.fromHtml(STRING);
to display it). Here is a part of the html source:http://pastebin.com/iVUeDbYV This is the element I want to display: `
HTML:
<option value="0">- A -</option><option value="1">B</option><option value="2">C</option><option value="3">D</option><option value="4">E</option><option value="5">F</option><option value="6">G</option><option value="7">H</option><option value="8">I</option><option value="9">J</option><option value="10">K</option><option value="11">L</option><option value="12">M</option><option value="13">N</option><option value="14">O</option><option value="15">P</option><option value="16">Q</option><option value="17">R</option><option value="18">S</option><option value="19">T</option></select>
I use JAVA and Anroid Studio, so I use a webview to load the url.
How do I do this?
Maybe you should rethink what you are trying to do, or rephrase the question? It's not really clear to me what you're trying to achieve. You have not really provided enough code to correctly explain the context. One line of Java code doesn't really help.
