Apps WebView: Wait until an input field exists before starting a javascript function
DaS4ilor
Hi all, I have a function to load on a website once its two input fields are loaded.
[HIGH] function setCredentials(name, key){
document.getElementById('zoneIdent').value=name;
document.getElementById('zonePwd').value=key;
GInterface.traiterEvenementValidation();
}[/HIGH]
It is contained in a `auto.html` in the `*root of project*/assets/www/` folder. (I tried putting it in the `/res/assets/www/` folder but I get the following from AndroidStudio : `Android Resource Packaging: [QuickPronote] invalid resource directory name: C:\Users\Yann\DEV\workspace\QuickPronote\res/assets`
I have to use this function on this type of website : http://81.192.152.242:8001/mobile.eleve.html?FD=1. Note that the website doesn't load quickly.
I'm using the following code :
[HIGH] myWebView.loadUrl(String.valueOf(url));
myWebView.loadUrl("javascript:setCredentials('" + name + "','" + key + "')");[/HIGH]
where `url`, `name` and `key` are strings that user has defined.
I tried it, even with dummy text, the two fields are completed and the validation action should be launched but it seems that either the function was loaded too quickly, or either it wasn't lauched at all, because once the website is fully loaded, there is neither the values apearing or an error message saying the credentials are wrong.
If your solution includes the use of external plugin-ins/libs like JQuery, tell me so.
