Help Weird icon?
Just got my watch Monday. Within hours, the always on display was not always on. Restarted the watch, no luck. Ended up wiping it and starting over. Same thing again, just took a bit longer. Of course my settings are right, as far as I can see. The only thing is this odd little icon on the watch that only appears after this starts. It looks like a light bulb with a line through it. A quick search of Google wasn't helpful. Nothing in the guide was, either. Any ideas? Sorry for the crappy pic. The screen barely wants to stay lit up long enough to do this. If you look at the pic as if you are looking at it like you would, it's the icon to the left of the center line at the top.
What is theater mode and how can you turn off and which firmware has it.
A new official Android Wear app is also available in the Play Store, which Google said will make it easier to switch between watch faces. It also includes a new battery saver mode that turns off a watch’s face to save power when battery is low and lets users view how much battery Wear apps are using, as well as a Theater mode that turns off screen and vibrations and a Sunlight mode that temporarily increases brightness.
Lollipop on Android Wear has a new feature that will make it easier to block unnecessary or annoying notifications from specific apps, and brings recently used actions to the top of the list when users tap on the watch face.
