Veils Demonic Vixen
I had solitaire, spider solitaire, or pinterest. Any of those would have been the cause.
http://s242.photobucket.com/user/si...media/Screenshot_2015-01-01-11-23-19.png.html
It happens at any tab I open on my phone. Facebook, gaia, google, photobucket... doesn't matter what website it is this pop up keeps appearing.Looks like the website you're visiting has been hacked in some way, or is serving up some script that it shouldn't.
Unless you've downloaded and installed whatever piece of junk its trying to install you should be OK, but I'd steer clear of the dodgy sites at the moment,, until they've had a chance to fix it
I did all of that to begin with.Usually, this happens at one specific site, but if it is happening on all sites, clear the cache and data for your browser (settings/app/), and reboot your phone and see if the problem persists. If it does, you may need to clear out the data folder for the browser (cross that bridge later, if it is needed)
