Help Weird (Problem?) when rotating.
katsua
Hey. Im not entirely sure if the thing that I talk about is problem or intended thing but it started to annoy me when i first spotted it yesterday(But maybe i was blind and it was from the very beginning when i unboxed the phone). The 'problem' itself is a little overlay thingy which looks like a form of transition when turning the phone around - The screenshot most likely shows it better than i can describe it .
My question is - Does everybody that uses S8 have the same thing or is it something on my side and if yes then how can I fix it?
Thanks For Help
Based on my phone what's happening to you is not normal. The switch from horizontal to vertical is so fast that any transition images are not visible to most people, let alone allow them to take a screenshot.
Problem could lie anywhere from a hardware (sensors) to a OS software issue.
Here is the video of how it exactly looks like because screenshot might not certainly show how it is - Is it still different from yours?
That's just a transition effect. My LG G6 does the same thing and I've checked a few of my other phones as well and depending on the GPU, it happens at different rates, but it's as designed.
Looks like human error. Wagon wheels appear to go backwards. Only so many photos per second.
The technology is not real life. The eye can't be fooled. Take led lighting as an example. You can't detect it flashing until you watch movement such as a saw blade or a propeller and you can see it's not a constant light. Just like a movie is only a series of pictures. The transitions are detectable under the right conditions.
