Help weird stuff after voodoo lagfix
webstar
I know that i should wait 2 weeks or so for the battery to stabilize, but it didn't even last 10h after using voodoo, and it was on 100%... Also, when the phone rebooted after flashing voodoo via kies, galaxy s screen flickered and it happens every time while phone is starting up, not after. Looks even worse then the picture below.
http://i55.tinypic.com/2dm5kaq.jpg
Don't know if that's normal, but it sure doesn't look like it is.
FYI it's voodoo 5 pre6
What should i do? Disable voodoo and reflash original kernel or just use it as it is, ofcourse if it's not anything serious?
EDIT: Also happens when charging and showing battery screen after turning off the phone. Flickers for a second, and gets back to normal.
that is exactly what happens to mine too !!!!!!
yes and also I get around 10 hrs only battery life when having 3G on.
Actually, it lasted below 10h with 3g off. That's why I thought it's weird. I could be that it wasn't voodoo at all, but that gallery sensor bug running although gallery is closed... Don't know for sure yet.
