Weird web browsing behavior.
pool_shark
Android Expert
Am I the only one that notices this?
Check for yourself. Set your browser to desktop mode and log in to gmail.com. The left pane doesn't behave as normal.
Also, if you set a background pic on your google homepage, the search bar is gone as well as the settings tabs across the top. You can poke at the page and eventually the search box will show up, then you can slide it all over the page.
Other websites are weird too.
Ive been having problems loading webpages... it will load one or two just fine and then hang on loading anymore unless i back out..
Just started tonight
As I suspected, it's a java problem. I disabled javascript and my homepage comes up but doesn't display the background image.
When I went to gmail.com, it complained that javascript was not enabled. This has to be due to the Oracle lawsuit.
