I have a problem with connection to my home wifi when i enable WEP/WEP2 PSK protection ...when I disable it I can connect without problems. Password I put is 100% correct.
try changing 'Country Code' and keep 'Channel' to 'Auto'. And which 'Wireless Mode' are you using? But I am sure that WT19i works on both 54G and 802.11B.
