pancho32392
Send me the link please I been try to find it and no luck
Which one you downloaded?
You have to download the ones from Battery Mods for the ICS Leak!
those were the ones that work for me, the one you downloaded gave me a bootloop.
pull battery out, and boot hboot, then hit recovery, reflash the rom, or restored your rom if you made a nandroid backup.Okay thank you and what happen if it give me a bootloop
i suggest you, to always make a nandroid backup, and keep it handy, just in case you flash something and it does not work, you don't have to flash the rom again, just restored your phone back.
hey, you could flash this one if you want, i tested it my self with midnight rom, and it works, flash it and clear cache dalvik.
http://www.mediafire.com/download.php?cyj2k3tnf49x51a
Yes, it works.Do you guys think it would work on mobster rom? Or would that be a no no?
