What am i doing wrong gps trigger
I created a profile to trigger an auto sms to wife when i arrive at work between certain hours. GPS location is set 200 meters around work location and between 15:00-22:00 but when i turned on phone at home, which is about 35 miles from gps set location, it sent the auto sms. What am i doing wrong?
AAArk7pRfA_Go1NeF_qgLEE5a
Profile: Got To Work SMS (16)
Cooldown: 43200
Location: 39.924346923828125 / -86.23924255371094 / 200.0m
Time: From 15:00 Till 22:00
Enter: Got To Work (17)
A1: Send SMS [ Number:(317)2007317 Message:Hey baby, i got to work ok. I love you Store In Messaging App:Off ]
I have found Wi-Fi NEar to be much more reliable. Plug in your office SSID ...
Code:
Profile: tlaOfficeNear
State: Wifi Near [ SSID:TLANET-2.4GHz/TLANET-5GHz MAC:* Capabilities:* Min. Activate Signal Level:4 Channel:0 Toggle Wifi:Off ]
Enter: tlaOfficeNearEnter
A1: Wait [ MS:0 Seconds:0 Minutes:1 Hours:0 Days:0 ]
A2: Perform Task [ Name:tlaWiFiOn Priority:5 Parameter 1 (%par1): Parameter 2 (%par2): Return Value Variable: Stop:Off ]
This one turns Wi0Fi on in my phone if I am near the SSID.
... Thom
Used to do wifi near, worked on my note3, but stopped working properly when switched to 6p. Wont trigger wifi near with screen off, but as soon as open wifi settings it will send it. Not suree if marsmallow or 6p has issues pinging wifi with screen off.
