I use GrooveIP pretty extensively on the Evo V and it is working well enough for me with a few caveats:
1) I have it set to wifi only. If Sprint doesn't have a heavy QoS hand in your area, it may work well for you. Where I live (north burbs of Chicago), Sprint gets overloaded and will routinely kick me down to 1xRTT from 3G, completely wrecking GrooveIP or anything using data.
2) Because I'm using GrooveIP with wifi, within the android wifi->advanced settings, I've set 'Keep wifi on during sleep' to 'always'. This is the only way to keep the GrooveIP-Google Voice connection alive. If you are using GrooveIP with 3G, it 'may' be able to keep the connection going with wifi set to sleep.
3) I had some receiving end echo complaints which was solved by enabling the 'Basic Echo Canceler' with the 'Echo Tail' set to the default 'auto-detect'.
4) Personal preference, but I have 'Accept Calls on Answer' checked so I don't have to press '1' to accept the call.
That's all the tweaking I've needed. Call quality is typical cell grade, so don't expect any audio improvements. That said it works well for me, and enables me to save enough monthly minutes to keep me in the $35 plan.
