lowboydrvr
Member
I also purchased the VZW power bundle and am using their case. The best part is it still works in the HD Dock (without removing the case).
I stopped by Verizon at lunch and picked up the Shell/Holster combo and was pleasantly surprised that it worked with HD Dock without the need to remove the shell. Didn't think I was going to like the shell however it is growing on me. Very nice so far.
That's the one I think I'm going to get, supposed to fit in the car dock as well. Does it keep a thin profile?
It does not.....floats around to much....have to take the case off to work in the dock....pia
I also went with the Otterbox Commuter case other than being a pain to put on I love the case.
but does it work with the nav dock?
How much thicker does it make the RAZR?
Just got the commuter case for the RAZR -- phenomenal.
I picked up the Shell/Holster from Verizon, thought it would come in handy if I needed total protection of the screen if I'm out on a bike ride or hiking, etc... It was a little pricey @ $30, but I get 25% discount still pricey.
Very nice construction, doesn't add much bulk with just the cover, I like how the area for the power and volume are left blank and the top and bottom are exposed. It is a very secure fit, the kickstand feature is sweet for watching videos or desk clock. It had sort of a slippery feel to it when I first opened it, kind of like a silicone residue. I wiped it down and rubbed it aggressively against a towel to remove the residue...has a secure grip in hand.
It also fits in the car dock, so I don't have to take the case off when I jump in my truck! When you remove the plastic insert of the dock to use a case you will notice the phone is a little loose in the dock. I put a small piece of adhesive felt at the base of the dock to take up the space....It's black in color so doesn't look too ghetto and does the trick I'm only showing pictures of the case, not the shell w/belt clip.....left that out in my truck
I found the same to be true with the nav dock and this case/holster..I love the case/holster but don't want to have to take the case off to drop in the dock, could you please post a pic of the nav dock with the felt so I can give that a try?
Good to know. That's thicker than I'd like, but if it does the job, I'll be happy.I just picked up an Otterbox Commuter (most Radio Shacks have them in stock) and it's great. To answer the above question about size after Commuter, it's about 1/2" thick (3/4" thick at the bump).
