Root What do I do if I checked repartition in odin?
paperwait
:o First i was trying to put basix on and selected the wrong update option in clockwork recovery.
Then i tried to reflash to stock with odin, i used a tar from the forum here that had like 7 .bin and .rfs files.
When i did that the phone would reboot over and over going through a factory reset everytime.
I tried to flash using the fisrt tar from here but with only 3 files in it. Didnt work so i checked repartition and flashed. Now it will boot to stock recovery but says device cannot mount /dev/block/stI12 (invalid argument).
Flashed again and nothing changed.
what can i do to fix this, if anything. anyone at all that has recovered a phone after repartition, how?
Ive seen this repartitioning mistake mentioned in other threads but no answers I could use. Thank you.
galaxy indulge metropcs
Here is what my screen looks like now when i power on.
edit: I got rid of the red writing at the bottom of the screen by using odin again with 7 files and .md5 attached. but no further.
Do you mean "Phone" instead of "PDA" in odin? I only have stock recovery on the phone with one option to update "apply sdcard:update.zip".
Major Thanks.
You guys are too good. Many many many many thanks for your help here. I'm downloading it now and will odin as soon as it finishes. I will then post here on how it went. Awesome work. :D
OK everything went very well. I have 4g and nothing has gone wrong with phone after messing around for an hour. Except I cant make or receive any calls? :eek: In phone info it says my phone number is 0000003675 and my MIN is the same. csc version unknown. what did I do, or what can I do now?
i think you may need to reprogram your phone. try dialing *228 option 5 to see what happen....
OK, so I called metro and got the MIN number they wanted me to use and it worked. Then manually changed it with ##626*. and that concludes this thread as far as I am concerned. Everyone"s help has been spot on and humbling. Thank you all very much, with special thanks to k0nane for what must have been hours of labor with the indulge. :D
Hi
I checked repartition in odin and now , my phone doesn't turn on. and also doesn't takes charge.
How can I do?
Use Option 2 with repartition checked again.
hi i did the same thing still stuck on E:can't mount /dev/block/st112 can I get help? I need step by step instruction because I have a hard time with this. ive tried just clicking repartition again and I just got u have to select a binary. so I am stuck. thanx ur help would be nice and very much appreciated k0ne, trying to get it fixed back to a position to install cwm purple with basix on it. thank u
I also was experiencing what seemed to bee a bootloop crash or something, but it was actually a modem crash error from notifier but closeing b4 u could see it, or I would have used ur one click
option. please need to get this fixed its not mine.
now I used rageagainst the machine in hemidall and I used it in the IBL and it now wont power up after a secessfull flash and reboot ? any suggestions as to what happened ?
vipofthc
:eek: First i was trying to put basix on and selected the wrong update option in clockwork recovery.
Am Also Suffering From This Problem < />
My Device Is Sm-t211 & It Not Turning On When I Open It The IS The Stuck On SAmsung Logo and Message Like
"ES:/fail to mount / invalid Argument"
i Also Tried to update it by odin but problem remain on the place nothng were Happend
Guyyz am Up to Head With This Please Help Me,,,>
Thanks In Advance
thesame here!I checked repartition in odin and now , my phone doesn't turn on. and also doesn't takes charge... can anybody tell me how to fix this?please...? any idea?
my device is Samsung j100ml...but i check the re-partition and got failed... when i pullout and insert the battery ,it doesn't turn on or charging also.. even if i charges it on a computer, doesn't work..
