So you get a fancy new Android phone or tablet and then something goes wrong forcing you to contemplate a factory reset as advised by the last-ditch section in the user manual - accompanied by a warning such as:
I would like to understand exactly what actually happens here. For instance, typically one or more Android system updates will have taken place on the device yet after the reset, the latest one will still be there. So your device is definitely
not restored to the state it was in when it left the factory.
In my
case I have an HTC phone that's unusable due to the HTC dialer crashing every time I try to make a call (right after 2.3.5 OTA). Factory reset and erasing the Flash has not cured it - so the problem has to be something persistent in the OS/program Flash areas.
I can't believe HTC would OTA an update that bricked the telephony on everyone's device out there, so I'm guessing the update itself is running up against something persistent in the 512Mb RAM... although I'm confused by terminology here, when it says 512Mb ROM surely that's not old-school ROM but Flash RAM that's reserved for the OS?
Anyway what more, if any, can be done to "clean" the device back to a fresh install of the current (or even previous) system?
