Um i moved it with an app called Files to SD CardHow did you move the files? Through a file browser?
As a golden rule don't move anything out of the /android folder as this is where local app data is stored, if you move it to your sd card a lot of apps will fail. Instead go into the phones settings, then apps and see if each app has a move to sd card option.
You can also move all the stuff in your DCIM folder which stores photos and videos from your camera. You should go into the camera options on your phone and choose store to sd card to save valuable space.
Any other folder is open to interpretation as they can be temporary files that apps use or storage for stuff you create within that app. However it really should not affect the app if you move the folders, just content you might have made. (Of course this might not be the case for everything)
As for games / apps that are now not working you will probably need to download the app again to reinstate the data. Although you may get lucky and be able to copy the folders back and have the app work again.
