What happens in "sleep mode"?
mrootes
Member
One of the settings I found is setting the time frame for "sleep mode". What is different in "sleep mode" than other times?
Here is something from the rezound manual.
Sleep mode
Sleep mode saves battery power by putting HTC Rezound with Beats Audio into a low power state while the display is off. It also stops accidental button presses when HTC Rezound with Beats Audio is in your bag. You
Thanks - so I wonder what the settings are for where I can choose the hours when it goes into sleep mode? What would happen if I made those hours all day long?
There must be some difference between this sleep mode and the one you provided in the manual.
As I understand it the phone defaults to something like 11:00 pm till 6:00 am. If you use the settings to make it all day it will just apply the sleep mode all day or to any hours you choose.
If you go into the menu>settings>power you will see the power mode. This is what I believe is being controlled. If you want to conserve your battery there are several settings you can use to optimize that for your personal use preferences. The sleep mode just modifies certain obvious ones.
Others are screen timeout, volume levels, auto updates, screen brightness etc.
If you play around with the settings menus you will find a whole lot of options that can be personalized. Have fun.
