gnosisjunky
Ok so a friend of mine handed me this phone to work on. This is nothing that I have ever seen before and i am at a loss how to fix this. Looking for an experienced modder/developer for this phone to help me with this.
This atrix is caught in some sort of frozen state in time. No matter what you do to this phone, if you restart it it will go back to exactly the same state every single time. You can delete every app on the phone, change every setting, do a factory reset, root, push firmware through bootloader, move apps to sd card, and none of it will stick. It's like the phone will not perform any function you tell it to do. After it restarts it goes exactly to the same state it was in. I have tried to downgrade the phone from 2.3.6 back to 2.3.5 using this...http://forum.xda-developers.com/showthread.php?t=1539167. The process completes successfully but when the phone reboots it goes into the screen with the android standing next to the triangle with an exclamation point in it. (forget what this is called) so you have no choice but to go into recovery and clear data/reboot etc. after that it boots back to the same place. Its like there is a nandroid backup somewhere on here that it boots up to no matter what. Factory reset does nothing from either the settings in the phone or from recovery.
The only other thing I can think to do is to get an img of the stock firmware to place on the sd card and apply update from sd in recovery but i havent been able to find one.
I think this is the first time I have every wished for a phone to be bricked so i could at least do something lol. Someone please help!!!
