Help what is going on with my storage?
I have recently bought a Motorola Moto G, XT1028 on Verizon.
When I bought this phone, I was told It had 8 GB total of internal memory.
Now I understand that includes space for the operating system and all of its components, but I'm getting screwed!
My phone has 8gb of memory, but in reality I have access to about half that. I don't even have enough room for the basic things I want on here because of the way the disk is partitioned and I want to know how I can fix it?
First of all, out of the 8 GB, Android has 5.5gb available to the user. That means the operating system is using nearly 3 damn gig. How is this? When the entire Android .ISO image is only 700mb AT MOST? The OS only needs roughly 1-1.5gb of space for itself and its taking twice that. On top of the OS taking 2 and a half gig of my very limited rations; the apps are reportedly using 1.75gb. This also doesn't make sense as I know that can't be true. I have nothing installed apart from the stockware that Motorola shipped, and even still, apps are megabytes in size. If there were 300 apps on here at 30mb apiece, it'd only be using 900mb.
One thing I have done was I switched from the dalvik runtime to ART in hopes it would lighten up its memory consumption, but perhaps a lot of that app data is files left over from dalvik? Or the ART just takes unruly amounts of memory?
The OS is using nearly 3 GB, the app data is using nearly 2, so all-in-all, I have 3 gigabytes available for MY files? what do I do about this?
Out of an 8 gig SD card, the OS, all its data, bootloader, recovery and all apps should not use more than 2 GB. how can I repartition the disk, or delete some of that outrageous app data to gain back my memory card?
Switching to art means all your apps will take up more space. It's the trade off for having them launch faster.
Rooting your phone would allow you to free up some space.
See also -
Check out "Storage Partitions"
https://play.google.com/store/apps/details?id=com.cls.partition
Because 300 x 30 isn't 900 so I'm not sure where you meant to go with that.
ART precompiles apps instead of on the fly like the Dalvik Virtual Machine. The compiled apps are then saved.
No part of the Dalvik was left when you moved to ART but the Dalvik cache is still being used, only now for ART.
Instead of repartitioning, I think you can root, remove some bloat from the system partition and move some of your big user apps there to free memory.
I think they make the system partition bigger than it needs to be for future bigger updates and updates to system apps?
