Still have a stock kernel. But,i want stupid speed...When I set the slide all the way over, I get "1000". But, looking at the actual tab, it says "9999"! Anyone set it past 1000?
how do you want to overclock your device when your kernel only supports 1Ghz. you need to flash some other kernel that does support overclocking. but if you want to do that you have to flash a rom that supports the kernel
