i am considering these two.
https://www.amazon.com/dp/B09ZMGQK4C/ref=redir_mobile_desktop?_encoding=UTF8&aaxitk=4fc5e09bf08f3db027bf02f5b1217f89&content-id=amzn1.sym.cf8fc959-74aa-4850-a250-1b1a4e868e60:amzn1.sym.cf8fc959-74aa-4850-a250-1b1a4e868e60&hsa_cr_id=0&pd_rd_plhdr=t&pd_rd_r=685b5c04-48d0-4fd2-b56d-00e5e5087228&pd_rd_w=JEcvE&pd_rd_wg=Frz11&qid=1666030054&ref_=sbx_be_s_sparkle_lsi4d_asin_0_title&sr=1-1-9e67e56a-6f64-441f-a281-df67fc737124
https://www.amazon.com/stores/page/BCA33206-85C5-49E2-9C5B-DA511A9B14F9/?_encoding=UTF8&store_ref=SB_A05265983Q0CE3UKZAZ7N&pd_rd_plhdr=t&aaxitk=4fc5e09bf08f3db027bf02f5b1217f89&hsa_cr_id=0&lp_asins=B09ZMGQK4C,B09ZMJWLRG,B09ZN1MHFK&lp_query=z fold 4 case with pen holder&lp_slot=auto-sparkle-hsa-tetris&ref_=sbx_be_s_sparkle_lsi4d_hl&pd_rd_w=Xflxt&content-id=amzn1.sym.cf8fc959-74aa-4850-a250-1b1a4e868e60:amzn1.sym.cf8fc959-74aa-4850-a250-1b1a4e868e60&pf_rd_p=cf8fc959-74aa-4850-a250-1b1a4e868e60&pf_rd_r=250XKN0Z3H3GP94NSVZ7&pd_rd_wg=HOEZ7&pd_rd_r=297cb964-73cc-4049-bdbb-c31cb7141e27
i was rocking the thin fit p on my fold 3. its a really solid case and does a good job at finding a practical place to put the pen. the pen is on the side of the case. but this is also where you have the power and volume buttons. so its a tad difficult to get to those buttons at first. you will get use to it though. also the thin fit p does not have any hinge protection. this is why the second one i linked might be the better option. it is more sturdier, but also more bulkier. this is a big phone already so a bigger case makes the phone huge.
just got a z fold 4 and bought this:https://www.samsung.com/us/mobile/m...3waPsvIRp16g0cAJVhhoCDc4QAvD_BwE&gclsrc=aw.ds just so that i can have immediate protection as well as getting the s-pen. its actually pretty solid so that now i can take my time looking. i may even just keep this one and not get the other two.
I use the S Pen and wireless charging every day - so any case that blocks one or the other is out of the question for me. I find the Thin Fit P to be a great case.
I like it better. Because of the elevation, it's at a perfect angle to type or view.I like the Samsung case but doesnt it bother you that you can't lay the phone flat on its back because of the elevated S pen holder???
I spoke too soon! Guess what happened last night?
In the accessories thread I had expressed concern that because the front panel is wider, the frame on the Thin Fit P case had to be thinner. Much thinner, and apparently TOO thin to withstand daily use. I removed my phone from the holster last night and found that the frame had snapped.
I'm filing a warranty claim but that's a bandaid on cancer if it can only last two months of normal use before breaking. Hopefully Spigen is working on a redesign.
To its credit, the Slim Armor Pro Pen Edition's hinge cover will reinforce that thin frame piece, making it more durable. It won't lie flat, though: but I don't use it lying flat very often.
actually emailed Spigen, asking if it's not too late if I can apply the cost of the Thin Fit P toward the purchase of the Slim Armor Pro Pen Edition. DOGGONE that's a lot of money for a case, though! It had better work and work well!
Don't get it. The pen holder is a terrible design. It's supposed to snap in place which it does. It is only snug when the phone is closed. But as soon as you unfold the phone, it's very loose. Luckily i bought it from Amazon and they are really good at returning things.i just ordered this........looks promising
https://www.amazon.com/Galaxy-Holde...035-884a-2041befef8bc&pd_rd_i=B0B8HRN9CH&th=1
the fit is really snug. it is so snug that they did not offer any stickies. its a nice case. i really like it.How snug is the fit? I've read comments that cases like this tend to be loose.
I like the idea of this case, which has almost everything including a kickstand! It's just a "one drop & done" thing, though, as the first gravity test tends to break the case...
https://a.co/d/88bWgQG
