Root What is the difference between 5860 and 5860e?
TechSys
Member
O.k. question time. What is the difference between the chinese 5860 and our 5860e?
I've been translating dashi.com, as much as possible without going insane. The Chinese have rooted the 5860. I'm suspecting the only difference is the e, which mean english. If that's the case, maybe we should look further on that frontier??
I've seen 3 or 4 roms and some root info, also some drivers. Just not sure of the difference between phones and if the stuff will work or not, on english (US) phones
Just an idea. Or am I just going off the wrong track again?
I believe the chip is different in the Chinese version of this phone they have no front facing camera or some other hardware and software differences the Chinese root i heard was not compatible but ,i wonder if you could look at the root files and figure what needed to be done for our phone ?
That's what I'm trying to figure out. If they have found an exploit in the os, we should still be able to use the same exploit to gain root. basically same phones with very little differences, I believe. I could be way off base though.
I am trying to get the files to look at them. Also trying to get a good translation that doesn't have weird wording in it.
downloaded a couple of the root programs on dashi.com, seems that there is another "menu" as you will, that is different from the 5860e. One program looks similar to odin and the other looks similar to super one click root. I have tried every key combination and cant get into a mode where these programs even work.
