What is wrong with the calendar widget?
candroid11
I would like to actually get some use out of this widget, but it keeps saying "no upcoming events." That is not true. I have plenty of events in my calendar. I can only assume that it will only show events that are scheduled for the same day, which is completely useless to me since I like to see things coming up in advance. The actual calendar app is working fine though, and all calendars are syncing correctly to my account.
There are plenty of third party calendar apps and widgets - maybe one of them will work better? I use Pure Agenda widget, for example, which lets me scroll months in advance, and most calendar apps also have widgets now.
Also, what phone do you have? The default calendar widget on mine shows an appointment tomorrow (just added it to test), but some manufacturers put their own calendar widget in place of the stock one, and we may be running different versions of android, so yours may be different.
I ended up buying the pure calendar widget. Thanks for the recommendation. It seems like just what I wanted.
