What means: Red "X" Android icon at top left corner of screen ?
Panchoevo
Also, seems for fave a sort of blemish or cloud icon next to it.
Phone is: HTC Evo 4G LTE
A picture or screenshot would be helpful..........................
There is also something that looks like a bunch of squiggly lines,
as though to suggest a cloud covering part of this red X icon.
For some unknown reason, this squiggly line cloud image does not appear in screen shots.
A couple of years ago, somewhere, I posted this same issue,
and got a ready answer.
Too bad that I don't recall the response.
You're using a cleaning app,Task Killer/etc... get rid of it yesterbay & watch it disappear.
Before you go into asking "Why should I uninstall my cleaner/Task killer",do some Googling,or,read my last 5 posts before this one.............................
