Root What OC kernel are you using and what governor, Frequency,Turner app, and so on .....
dvdavid888
What OC kernel are you using and what settings governor, Frequency,Turner app, and so on ..... Are working for you? I want to see what configuration is working on most Zte Awe phones
Currently running the latest CM11 (includes OC kernel)
Trickstermod:
- 1024/fiops SD Read Ahead
- 1.7ghz/Wheatley
- MP-Decision OFF
- Temperature throttle OFF
- 400mhz/Performance GPU
- Undervolted 2 notches (hit negative twice)
Runs ABSOLUTELY SOLID, no crashes/reboots/force closes, apps/games (mostly games for me >_< ) load and run at peak performance. Also doesn't get hot after long usage, even when running FPSE emulator over 1.5 hours (must...find...echo of bat in SOTN. Where are you dammit!!!!)
I am currently running L Awe was wondering what Oc kernel is available with Oc GPU and voltage control
Can't wait to get off work to give it a try might have to leave early just so I can go play :D:D I have bin running AWEstruck_v1.03c has bin running smoothly can't wait to put AWEStruck_JB_beta6 thru the tests Thank you Spock you made my day
What is the average/recommended temp the CPU and Battery should be running at? I know the cooler the better just trying to see what temps are average.
This is on the spirt rung at 1.89 MHz 3c tunner and mp off and trickster and the CPU controls on the rom
I think It'd be nice if someone would just make a sticky for OC stuff. I know in my case, most of the options with Kernal tweaker are awesome but I don't know what to do with them. A guide on the OC stuff demonstrating settings that are working for the more advanced users would be a huge help to me and I'd think others as well.
Edit: I got to thinking about it and thought I remembered a section in the "All Things Root" thread so I checked and yes, an OC section is present. I've read parts of the big "kernal awestruck linaro" (something like that, its linked in the OC section) and it has a great guide within it but I haven't really found much in terms of specifics for tuning and such but I need to read the whole thread because as big as it is, some info could be there. I come to this forum everyday so no excuses, I just need to do it.
