Root What rom and Ex2 help?
gibbo1982
Am looking for a good fast stable sense rom for my htc desire gms.
Been trying a few gingerbread roms and I dint really like them. I need to have the feature to pick 2g/3g or auto.
I also used gparted to make a 1gb ex2 partion to solve the memory problem. But my internal memory on the roms I have tested still shows up as 100mb or so.
I downloaded lan app off the market and it found the ex2 partion?
Try Teppic or LeeDroid.
As far as I understand Teppic is stock possibly with a2sd, you'll have to look.
LeeDroid is tweaked, so I've been told.
Sometimes you need to run the terminal emulator to enable a2sd but that depends on the rom.
Seeing as I don't use them I can't really help any further.
