Help What should I expect for battery life?
svensett
After owning my Touchpad for about a year, I finally took the plunge and installed CM9 last night.
Just wondering what I should expect for battery life. With WebOS I could go days without charging with minimal use whereas it's down to 39% since the install yesterday. I'm guessing it will get better over time like my phones, but will it get close to WebOS?
TIA
Close, but not as good. I get 30 ma draw during sleep, which is about the best you can do. You can check it with CoolTools. Just set it up just for battery, no graphs, then let it sleep a bit and check it when it wakes. CPU Spy should also show you're in deep sleep for around 90% of the time when screen off for an hour.
