What the most stable ROM for Zte Zmax Pro
newbie321
I see a lot of custom ROMs for the ZTE Zmax Pro. Unfortunately, all of these have somethings that do not work. Other than stock ROMs, are there any recent ROMs that provide full functionality ie all hardware works?
Is there anything for Nougat and/or Oreo?
Thanks,
do you have a custom recovery? if so you can always make a nandroid backup and try these roms out. if you do not like one you can always just restore one of your nandroid backups.
yeah.... I have recovery and I tried all custom roms I could find. All of them have some major issues for some reason. Some don't start at all. Others start but camera does not work, or flashlight or soemthing else. The only one that works is stock ROM, which is 6.0.1. The problem is that some apps (Expedia, for example) no longer work under this OS.
It would be great to find ROM that has all features working.
I've looked into this as well and basically for me I think I'm just going to go the routing option and then add applications as I'm going along.
it's still a great phone and has some great hardware specs but Laurel is moved on. the fact today you can get a phone with 8 gigabytes of RAM and 256 gigabytes of internal memory for around a couple hundred bucks or less and if you get something that's refurbished or used then it's around $100 that were Flagship phones just last year really does tell you a little bit about the value proposition of messing with the older Hardware.
from what I understand the Samsung S3 still has pretty good support and I still have one of those but then again I just kind of use it cuz I like the OLED display.
1 places like Walmart mobile and other value carriers no longer support the phone you know there's some things that are going on with it
