Accessories What's the biggest battery I can squeeze into an Innocase?
MisterMixelpix
Android Expert
I have a Seidio Innocase II, love it. Also have a 1750. Would like to upgrade the latter, and I'm wondering what's the biggest option I could jam into that thing, even if it means pulling the back of the Inc itself off.
Votes?
I think thats about it. I have the same setup and I don't think there is a bigger battery out there that will fit. Good luck though..
thats it. there is no other battery that is bigger in actual MAH that will fit. remember the 1750 is not actually 1750, closer to 1600 maybe
Yeah. You will not get anything bigger in their without cutting holes in your case, and even that will not work because of the way the innocase slides on. I cut a hole in my back plate, so when my 2600mah is in--it just hangs out. The overall thickness is the same as the case, so it still fits in my clip if I reverse it so the screen is out.
