Well app2sd will make you a list of all movable apps so you don't have to go through each app and see if it can be moved. So it just saves time. At least that's all I can think of right now.
Good point. Now, I see like a half dozen different apps that say "app2SD" or some close variant on the same name. Does anyone have any recommendations on which one they use and why it might be better than the others? Or are they all more or less equal? Ratings seem fairly close for all.
(Stock) Gingerbread has this now too
