Whats up droid users!!!!!!!! Need some help here!!!!
R0k5tr
Member
i need some help trying to put the n00b vI rom on my phone as well as the theme for it as well. everytime i use the power button and volume up key to load the rom it tells me the /sdcard/ cannot mount... can anyone tell me what the problem is? i formatted the sd card used titanium backup to backup everything and it still won't work... HELP ME PLS!!!!!!!!
thank you,
R0k5tr
Have you tried reading the card in another device besides your phone?? A computer, another phone, card reader, etc.???
I'm just trying to see if there is something physically wrong with the card or your phone..
I had the same problem a week or so ago after buying a new Micro SD Card. I tried to mount it and format it but kept getting the same error message.
Try this tho. Just download to your computer, unzip and run as admin.
https://dl.dropbox.com/u/65761686/sdtestandformat.zip
I recommend you transfer all your files onto your computer, copy a few tiny files back to the SD card. Run this program. Depending on the size of your SD Card it will take a while (my 16GB took almost 3 hrs, start to finish). But when it was done everything worked, no mount issues just good to go. Hope this help and good luck!!
