Help What's your average battery usage.
Gilmour
Member
What's your daily battery usage. Mine all of sudden seems abnormal.
Check this out and share yours.
I'm on April update.
I've used 40% in the last 15 hours, with 3 1/3 hours screen-on time. That's lighter usage than some days, but in line with expectations for that amount of active use. I'm on the May update, but haven't noticed any difference as a result of updates.
Of course battery consumption depends on many factors, even as simple as whether you are using it indoors or out (on a sunny day the display will use a lot more power outdoors due to the higher brightness).
If you look at Running services in Developers Options, that might reveal more to you than the Battery usage menu (... in my phone there's also three-dot icon in the upper right, with a Show cached processes option).
That drainage happened on may 9th. The next day May update came out so I haven't had any battery drainage since update.
I forgot to mention that on my 9th. I had very odd auto brightness behavior. It would go to peak brightness all the time even in the shade. I did restart it a couple of times but still acted abnormal. Luckily a nice waitress at the bar let me used her wireless power bank(she didn't know that she had that feature on her power powerbank )
