Help whatsapp is duplicating contacts
YossiN
I'm using the 4.4.2 version with the stock contacts app and having a problem that Whatsapp duplicates my contacts
Before installing whatsapp I had 1 contact:
Smith family
John 12345
Ann 98765
Now, after installing whatsapp I have 3 contacts:
Smith family
John 12345
Ann 98765
Smith family
John 12345
Whatsapp 12345
Smith family
Ann 98765
Whatsapp 98765
If the contact have only 1 phone number it doesn't duplicate itself.
No other change was made except installing whatsapp.
I filtered the list to show only the gmail accounts so it showed me only the original contact. But in the search it shows, again all the 3.
Of course, what I want is one record:
Smith family
John 12345
Ann 98765
Whatsapp 12345
Whatsapp 98765
1- Why did it happen? How do I overcome it?
2- Alternatively, are there contacts apps that DO know to “merge” the records?
Other ideas?
thanks
One possibility is that you are allowing WA to sync with one of your email accounts. If so, it will download the same contact multiple times. I had this problem until I discovered that all my email accounts were set to sync contacts.
