Just installed sholes 2.0.6 and temp monitor for my cpu temp. I am fairly new to the overclocking world and don't want to mess anything up. What are some good temps to be seeing running at 1 Ghz and at what temp should I stop what I'm doing and let things cool down?
Check My posts there and further down the thread for the information I looked up
EDIT: Just noticed you have TempMonitor installed. I do not believe 2.0.6 has the correct kernel to get a true reading on the CPU temp itself, just the battery. So far it seems as long as your battery is in the safe range, so is your CPU. The newer bugless beast ROMS have the correct kernel, BUT people are complaining their Droids are running quite a bit hotter on these ROMS.
