when using a home replacement....
ChronoVII
When using a home replacment like Helix, Home++, etc. does the android home still run in the background and reduce performance? I had a lot of stuff on my stock home but just switched to Helix so how do i stop/disable stock home if it is running?
thanks!
It's a good idea to remove all of the apps and widgets on the home screens if you leave it. If you're rooted, you can use Root Explorer to rename the stock launcher (add a .bak suffix) or copy it to your SD Card, so you have it if you need it.
